Spring compressors question
Car  Ph2 Flamer
Am thinking about getting some Eibachs and have just been reading this in the guides section http://www.cliosport.net/forum/showthread.php?579168-Fitting-lowering-springs-to-a-Mk2-Clio on how to change the springs etc.
The last post in the guide says
Re: Fitting lowering springs to a Mk2 Clio
You don't require spring compressors for RS models. That said anyone working on a Mk2 non RS will be wise to use them.
As I don't have compressors and do have an RS I don't want to buy a set if I don't need to but I've always thought compressors were essential.... Anyone who's changed their springs care to confirm or contradict?
I used spring compressors on my 1.2 16v when I changed the springs wouldn't do it without them IMO
Didnt need them on the clio but made my own from some threaded rod and some make-shift brackets for a mates bmw! much cheaper
Its easier to do it with out when you have someone to compress the spring so you can wind the nut on. Can be done alone though.
Can be done with out them, i changed mine without them.. was still shitting myself undoing the nut :S Just get somebody to push down on the spring slightly as you undo the nut then release slowly, there really isnt much compression in the springs to worry about!
no need on a sport, i've done about 40 of them!
just a bit of pressure as you undo the nut.
