I’m about to upgrade from Eibach Pro’s to something stiffer.
I did email Eibach, but they will not tell me the spring rates for the Pro’s.
Any ideas what rates the stock springs and Eibachs are?
According to GAZ their kit is fitted with 250lbs/in (44N/mm) front and 225lbs/in (39,5N/mm) rear. Seems a bit soft for track use too me… I was thinking more of 400lbs/in front. For the rears I need to measure the MR and calculate…
Please let me know what you think. What spring are you using / would be ok for occasional track use but still bearable on the road?
I understand that the characteristics of the dampers are as important as the springs for the ride quality.
What rates are the Clio Cup racecars using?
