Sqeaky clutch
Hmm well it's quite normal to squeak after a head kicking but it shouldn't really be doing it when you're just plodding about.
I can't hear it as I'm driving about only when engine is off and I press the clutch in! Was wondering if anything could be done to stop itc
Clutch Thrust Bearing.
You get one with a new clutch kit. I'd recommend doing the clutch as well.
Wait, engine off?
No!!^^
Its down to the plastic pivot bush inside the bell housing which the clutch fork pivots on. A tiny drop of wd40 will sort it
