Squeaking/grinding drivers side suspension?
  145db Euro'd clio
when i turn to the left it makes a horrible grinding and squeaking noise. only at low speeds(although i may just not hear it at high speeds)
It did it last night, but was fine today then started again tonight. I also found that the steering felt a bit all over the place on the way home from work just now but this may be my mind playing trick on me. My power steering pump is on its way out? this the culprit maybe? I makes a noise anyway with the pump going but this other noise is much more noticable. Checked the spring and shock today and everything seemed to be in okay condition....
Help greatly appreciated as its totally baffled me
