squeeking noise
BIFCAIDS
  340i M-Sport & 182
it happens when the cars moving its a high pitch quiet squeek but it stop's once you start braking anyclues?
Taa!
  PH1 172 Sport
well usually if its a stone or piece of grit etc ..it will come out with some hard braking. It may not be that problem at all though just a guess from experiance.
  Mondeo TXS Bardge.
could be the hole in the wing mirror on the drivers side, where the temp sensor is on european version, the uk one beingo n the passenger side, apprenlty some people get wind whistling through it over say 30mph and can be quite annoying apprenly but when you slow down it stops.
BIFCAIDS
  340i M-Sport & 182
hummm thats a good one im gonna try it with some tape nice one jaffa
  96' 1.4 Clio RT & Polo
I get the same problem on my 1.2RL - had the brakes checked out, but still squealing...any ideas on that?
  RARE Unmolested Corsa sxi
pads making slight contact with the discs?
i get a slight squeaking when going around a round-about. Mind you, ive had new discs and pads less than 800 miles ago.
  Mercedes C Class Sport
^ I had/have this issue. I replaced discs and pads and apparently they needed 'chamfering' (filing down). Its stopped but does it occasionally
BIFCAIDS
  340i M-Sport & 182
ive been out in the car n it wasnt making it (going back to the hole in the mirror theory) the car was wet n the hole had water in it
  Mondeo TXS Bardge.
if its the hole then i'm sure a but of silicon or some gaffa tape from the inside would sort it, but i'm not sure if the hole is required for drainage purposes.
