Squeeling noise??
Car  Low 'n' Slow
I seem to be getting a squeeling noise when i change gear, sounds like a fan belt slipping. when i lift the clutch it starts, if i put the clutch back down it goes away. only seems to happen when the car is cold
I've had my aux belt done this year, could it be this? or does it sound like something clutch related?
:dapprove:
have you checked the belt tightness, there is a little bolt on the charger motor thing, can't think what its called cos im drunken, its at the front of the engine, 10mm spanenr and tightnen it up some more
don't think its the belt, so looks like the clutch realease bearing
cheers guys... looks like a new clutch kit for me then
i've not had one fitted yet. been moving into a new flat. will be going to get one sorted this week or next as its getting worse, will let you know if it sorts it
my clutch release bearing started squeeling, within 4 days the clutch pedal was jumping up and down on its own, 2 days later i couldnt get any gears lol, guess what im doing this weekend, if youve caught it early and can do the work yourself the clutch release bearing is about 14 notes from your dealer
Seems a shame to get all that way to the clutch and then not replace the clutch while your at it?
