JoshOm3
Cup'182/Rs2'd Trophy
Ok. Did a little search here last night and didn't find alot so ill post and ask instead.
All oil leaks btw.
Got oil blowing over onto my two water pipes as they head into the bulk head. (Matrix pipes). Oil breather seems to be pushing oil out. Ive checked the level and its ok, not over flowing etc. Theres more oil sat on top on the rocker where they meet, its more than usual so im wondering why. The oil breather pipe (plenum side)Also isn't jubilee clipped, but never has been. Last of all my plastic cap(cam cover) nearest the bulkhead seems to be weeping a little oil too. Im
presuming that just replacing the cap won't do and there's more too it behind?
So, question is.
Whys there oil under my plenum more than usual?
Shall I bung a jubilee clip onto the oil breather? (Bare in mind never had a problem)
Would a new plastic cam cover sort the leak or is it something else to it?
ps; all of this has occurred after fitting the ktec induction kit.
Thanks, josh.
All oil leaks btw.
So, question is.
Thanks, josh.
