Standard Airbox vs Fatty Induction Tested
CasualBG_182
Hi Guys,
A few months back I had my car mapped at EFI. The engine is close to standard, it's had the centre silencer deleted and the catalyst modified to remove the olive join.
I was unsure about what induction to run so kindly Chris at EFI offered to test both the standard airbox and the fatty set up back to back. He did three runs of both and here are the results: Black is airbox - Red is Fatty
As you can see the standard airbox has a noticeable spike in torque in the mid rev range!
In the end I decided to run the fatty for the remap and here are the results of that: Red is standard with fatty, Black is mapped with fatty.
As you can see the there are some good gains with the map throughout the rev range!
Interestingly, Chris reckons that a remap with the standard airbox would see similar gains throughout the rev range and keep the mid range torque spike you see in the first graph. I'm happy as even with the fatty, I've still got plenty of low end torque. Car drives really well and idles nicely, not a massive peak gain but you really feel that extra 'area under the graph'.
Big thank you to Chris at EFI for doing this for us, I was looking for this info before I got the car mapped. Hopefully this will help other people make a decision on what they want to run!
  Land Rover
The standard air box will have been designed to deliver the most power while being effective at filtering air.
I believe that the “acoustic valve” so readily binned by owners is there to increase mid range torque by altering air flow in some way.
imprezaworks
  Mk5 Golf GTI :)
Mines mapped with a fatty style kit, similar figures too yours.
Sorry yours is 167lb mine was 163.
CasualBG_182
The acoustic valve was installed for this rolling road run.
Brigsy
  T.Turbo
I wonder how the v6 espace airbox compares to the above?
I have tried a couple of different setups on mine - have also noted that low down torque feels better with stock ph2 box compared to v6 and ph1setup. Top end pull feels better with the latter though.
  Megane R26
I run a Ph1 airbox
with Itg filter on the side of the throttle body.
Sounds brilliant without the cold air feeds but I keep them on, not sure I notice any difference.
  Land Rover
I have got together all the parts to refit the standard airbox to my 182.
But it’s been rolling road tuned and if l fit the standard airbox l assume it will mess up the tune.
So currently the parts are in a box in my shed.
  Land Rover
Strange that the PH1 has the better airbox as the PH2 develops more power. You’d think they would retain the better design as l am sure everything would have been looked at in the efforts to improve BHP.
  Megane R26
I believe Ph1 has better head with bigger exhaust ports.
182 manifold is where the 182 gets a bit more power, I have one on my 172.
  Land Rover
But 182 BHP from a normally aspirated 2.0 litre is still good going for a standard road car back in 2003.
My 1998 Alfa Romeo 145 2.0 Cloverleaf had all the toys, VVC twin spark plugs 16v fancy manifolds etc and while a great unit it still only managed 155bhp.
The engine was used in the GTV and other Alfa’s well into the new century and BHP never reached 182.
  Land Rover
Mine was putting out a rolling road varified 180bhp at the wheels with just a Janspeed exhaust, decat, induction kit and remap.
Before the remap (but still with the other kit) it was about 30bhp less.
It still managed the same economy as before, and passed the MOT last month.
I had to refit the CAT for the MOT of course, so power is probably down now, but it shows what can be achieved.
Fortunately the CAT was supplied with the car when l bought it.
I may get the remap done again with the CAT installed, but tbh to actually drive it feels pretty much the same as before l refitted it.
  Land Rover
No at the wheels, on a rolling road after it was given a custom remap. (using said rolling road)
Before the remap it was about 150bhp at the wheels according to the printout.
I would expect a standard Clio 182 to put out close to 180bhp at the flywheel.
CasualBG_182
Got a print out? 30hp gain from an exhaust and remap seems... a lot...
