Standard clio alarm question
  182
Hi, i want to adjust senstivity of cobra standard alarm been told the control dial is under the dash by passenger air bag ive stripped dash down and no where to be seen anyone else know where it is its the clio II ph2
DrR
  VW Golf GTD
Never heard of this. Only swaping the wires round on the sensors.
  Clio 182
whilst on this topic, why is it when i lock the car from the outside the lights flash but only sometimes will it make the beeping noise?
  330 Ci
When it beeps it means the volumetric sensors have been deactivated - ie they won't detect motion... useful if they're false triggering and setting the alarm off all the time. I think it has something to do with how quickly you get out of the car after taking the key out of the ignition.
You can "set" the alarm to do this on exit manually though by turning the key in the ignition twice before exiting.
  182
i dont want to reduce i want to increase.. i rock the car as hard an an earthquake could but nothing.. generally i want it to go off if say for instance someone tried to steal my rims by jacking car up
