Standard Clio with V6 Centre Console
  GOLF GT TDI
I am looking at getting the centre console bit off a clio MK1 V6 but i am not sure if it will fit, I have attached a photo so you can see what part i mean.
Posts are appreciated
Stuart
® Andy
  Illiad V6 255
Not sure it would fit since the gear stick is raised on the Vee. It then heads back past the handbrake and ends up butting up high against the front of the engine bay.
If you do need to get the part from Renault I'd expect it to be very expensive since all the V6 unique parts attract a hefty premium :(.
  GOLF GT TDI
but may be it would head towards the back of the rear seats hopefully :D i havent ever been or looked in a V6 so i am not sure
® Andy
  Illiad V6 255
Bulkhead in the Vee is tight behind the front seats level with the door pillar so it'll be a "legroom" short of the base of the seats.
I'll have a look when I get in the car in a mo to see how many parts the central console is split into. Think the front might be separate from the "tail" for the handbrake etc..
  GOLF GT TDI
well if it is hopefully would fit does the mk1 phase 2 clio have the silver centre as well? like the mk1 phase 1
  2015 Audi S3 Stage 3
ive checked this out before and afaik it will not fit due to the raid gear stick and where it fits against the engine!
other than that if u want to custom adjust it be my guest and let me know how u get on ;)
I have MK1 172 and MK1 V6 Not a straight fit I can tell you.. May be able to make one fit but would be a bodge job unless your good at that type of thing?
  A well built VW
There is a french site that sells one for wht you need for around 100euros I dont have the site but someone on here posted it
