Standard HU & Sub
Car  Megane DCi 147bhp/350nwm
I've been there with the aftermarket subs etc and had stupid loud install but now i've decided standard is better but i just want some more base but dont want 6x9's...i think i'm looking for something very subtle such as a 8" in a stealth box or something to keep the standard look
How easy is it to wire it up to the standard headunit?
Its a piece of piss but you would still need an amp to run it. Take your feed for the amp off the rear speakers and then run the sub of the amp. If your only doing a 8" you wont need a massive one.
You wire the rest of the amp up the same as you would normally (ground wire to earth etc) and you need to wire the remote lead (The one that switches the amp on to the rear of the hu - I think its the grey wire but you would have to check). Apart from that its done.
