standard ph2 rear lights.
Car  LY 172
what does the top left bulb work for? Mine dosent do anything. So have changed the top bulbs to be the brakes. i dont like dual fillament bulbs lol.
On the right hand side it is a foglight. The left can be wired with a live from the right, so this also can be a foglight.
im confused, do you have a ph2 bulb holder??
and youve re wired it so the side light is at the bottom and brake is at the top??
i think youll still need a dual filament in the bottom because of the shape of the plug
and where are you going to put your fog dare i ask?
yeah i re wired it so what the bottom is the side light. And yes using ph2 holders. so what should be fogs are now brake lights. and the left side reversing light is now the fog lol. i found some LED bulbs that fit as sidelights. So dont need dual fillament bulbs.
Only did this as i prefere to have my brake lights and side lights seperate.
Sounds like a big ass waste of time to me, what's wrong with the sidelights and brakelights being in the same place?
it barely took 2 mins to do. Just switching the pins over.
And i did it because thats how i like my lights to be. + makes brake lights more visable.
so does that mean youve got a nice red bulb in the clear circle of your light??
i can see where your coming from, and may look ok, as long as you can get a silver vision red bulb thats bright enough to be a fog light,
i like two reverse lights personally, plus it sound like more work than i can be bothered for the back of the car.
so wheres the wire for the right reverse light going now?? is it just hanging out?
right hand side still has the reversing light in the standard place. So no the wire is pluged in as standard.
I sprayed a standard red led bulb with silvavison spray. So looks silver untill used. It turns red.
So you've also lost a reversing light which you need for reversing in the dark, and you've put it on the wrong side to be legal in this country.
the fog light has to be on the off side to be legal, also it needs to be bright, by the sounds of things its not gna be bright enough if it hasnt got the red reflector and is covered in silvervision spray, so on the left side, where does the wire for the reverse light go?? my ph1 has reverse lights on both sides
didnt realise the side the fog was on was important so have switched it over. being an LED its plenty bright enough
