Started with Jerking now cuts out, Wht does this light mean? ASAP
  White 1*2
Guys...
this lights is appearing on the bottom right on my dash what does it mean?
its a 2002 172.
When it does the car jerks then carries on as normal.
i pulled over and when i went to pul away it comes on and stalls everything,
ive drew a very technical diagram of the light lol
Ali
  V6, Trackhawk, GTS
Not seen that one before. Looks more like the shift light...
Is it not in the Handbook?
Da
  Less
It's over revving as said above. That light is to warn than the engine is hitting the limiter.
Da
  Less
Could be so many things, difficult to know where to start.
Try disconnecting the throttle position sensor (which is on the pedal) and start it up.
  White 1*2
i did, i showed the throttle position and 2nd lambda as i got no cat
throttle position on the tb or on pedal?
it went onto 3cylinders today.... coilpack maybe?
