Starter Relay Where to Buy??
Car  BG 182 FF CUP
Can anyone advise me? Been having intermittent issues with the starter relay!
And does anyone know if I can remove the A pillar sensors without making the alarm go off all the time? Due to full cage they’re interfering so currently popped off out of the way
Regarding the ultrasonic alarm sensors, if you follow the cables they are plugged into the alarm wiring loom behind the dash board, and if you unplug them from there they will be fine.. Your alarm will still work through the door switches and won't false alarm..
Sent from my SM-G977B using Tapatalk
Brilliant thank you very much!
