Starting issue
  Clio 172 2001
Ok so I've googled and searched the life out this problem tried everything except look at gearbox earth will do tonight. But so far i bought 172 non runner off a mate it always randomly cut out ect worse on bumps. He then parked it came back to the car and it wouldn't start and now it randomly starts for 10-20 seconds but misfires like mad and then cuts out I had it at 2500 revs for 5-10 seconds then it just died revs dropt and it cut out. I fitted another 2nd hand crank sensor then a new sensor still no joy. Won't start with easy start ither (bad I know but worth a try) also the imobliser light doesn't flash when I start it I seen some people had that mines is ok also can hear pump priming. Only fault codes are both 02 sensors but it's had them for a while because of decat pipe. I've cleaned throttle body aswell
It's a 2001 172 clio
  Clio 172 2001
Il check O2s at some pint then mate and to update I'm getting fuel but very weak spark so possibly a coil pack
