Evening folks
Got a 182 that's in the home straight to becoming a track car. Last 1 or 2 things to sort out and now I'm having starting issues!
Firstly, I think the alternator has just packed in. But even with a jumper pack on the battery the car will only turn over and not start at times. Would a failed alternator cause it to not start and just turn over?
Randomly it will start, but doesn't seem to be a pattern to it.
I have read the codes with a decent diagnostic kit and apart from airbag and aircon faults as they have been removed, the only "real" faults I can see point towards the throttle pedal. Something along the lines of track 1 and 2 not being the same? I'll get a photo of the codes next time if that would help. Would a throttle pedal issue cause the engine not to fire?
It will turn over fine but not fire.
Any advice on what to check next?
Greg
Greg
