Steamed up head light
  Suzuki Ignis Sport
Just noticed one of my head lights has steamed up, anyone know why this has happened?.. the other one is fine..
  ph1 172
is the bulb u put in halogen? and did u or whoever touch it with ur fingers when puttin it in? if so that cud be why..
  Lots of Alfas
It wont really go away, it could get worse, you need to dry it out and seal it up with a rubber cover.
  Suzuki Ignis Sport
Still no progress, in fact its gotten a little worse. what should i do?? It's constantly outside, because i don't store the car in the garage.
mossyv6
  Trophy,V6,5GT,AG200
Sounds like the lamp seal may have perished. May need a new deadlamp?
But first try removing the headlamp and get a hair dryer on it, low heat and dry through the bulb fitting section. Leave indoors overnight and refit with all rubber/plastic covers.
  Clio 182 & Saxo VTR
No.
The simple answer is that moisture is getting inside the lamp and condensing. Headlamp off, silicone sealent on your finger and run it around any seals. Leave to dry inside overnight (take the bulbs out by the way so you allow any moisture to escape) and wipe away excess, assemble on car. If it still does it then you didnt seal it properly. Repeat. :p
  Suzuki Ignis Sport
Went to the stealers to get some advice aswell..
The guy sed that theres lots of water in it... so only want is to take it out, dry it, and seal it.. as you sed diesel...
But having sed that , he also sed try leaving the full beam on for a while, and see if its clears up, beginning to clear up i must say, but startting to steam up in the indicator bulb area! :(
  Suzuki Ignis Sport
Right, i just happened to recieve my new headlamp today, but only remembered that my lights are darkish, nto the grey one :( and the grey one turned up! DOH!!
But good news, the steam and mist has gone from the headlamp, but left some and i mean a very few some water specs.. have i gotten away with it?? it will gradually dissapear?... or will it stay there forever?...
Coz i have MOT this week, u reckon i could get away with it??? coz the specs of water are only on the sides... thx
  Clio 182 FF + Cup Packs
Apologies for the post above! bloody enter button.
Anyways... I have noticed the same problem and got a new seal on the headlight by the stealers. Its still steaming up a bit. I`m wondering instead of taking the whole headlight off, would a few of those Silica bags (ones found in your show boxes) over night and then seal up again sort it out??
Sib
  Clio 172 (Silver)
How do you plan to get them back out?
I have the same issue on mine and have tried all sorts
  Suzuki Ignis Sport
I think its the ever changing weather conditions, from warm to cold, to warm to cold etc...
  172 A Cupwork Orange™
Renault Dialogys says steamed up headlights are normal if you wasnt to get rid of it quick turn your headlights on for five mins thats thats the advice it says to give to customers app its normal and not to worry about it....
I`ll take the idicator light and dipped light cover out, put some silica bags in over night and take them out in the morning. See if thats taken out the mositure. I`ll let you know how i get on next week...
  M2 Competition
Attatch them to a bit of string, drop them through indicator/ bulb holder holes, and then when you're done, pull them out with the string.
  106 GTi
Indeed - The outer cover is not a sealed unit hence you may get some moisture build up in - due to the fact it is not sealed as said it will dry out by its own accord.
  Clio 182 & Saxo VTR
Headlight idea is to generate heat and help the water evaporate, it wont work unless they moisture has somehwere to escape to so take out a sidelight bulb and wire so theres a small hole. Also try a hairdryer on the outside of the lamp too, speeds it up.
