Steering column?
right guys, when im driving down the road it feels as if i have to move the steering wheel about half inch before the car actually move to the side, is this a column fault as i read that its a common problem
james
p.s if so has anybody got one
sweet, thanks mate, will probably just buy a new column which has already been welded (one on ebay at the minute)
james
Lunner said:
WHY???
Yourt column can be welded in the car at a cost of about £10-£20 in all of ten mins, i've had 2 done
:eek: sorry mate, didnt know if it had to come out of the car to be done.
so the point at were it needs to be welded is accesible from under the car
the guys at work will weld for nothing :rasp:
james
you get to it from the drover's foot well, pull up the rubber boot and you'll see the joint where there is play, will prolly have rubber stuff comming outa it, make sure you dont' get it too hot when welding it or you'll melt the UJ grease
Bit difficult to do a proper weld job while its in the car, personally I didn't find it that hard to take out and replace, would have taken an hour if I hadn't of kept forgettin to plug the speedo in before i assembled the dash!
how comes the dash has to be removed if you get to it from the floor
james
sweet, many thanks mate. guess that will be a job for this week then
james
Sami said:
Sorry mate I meant to change the column which is what I did.
ahh i get ya now mate, yeah i have recently replaced a few dash bulbs and had a quick look and realised that the column is under the dash
james
