Steering feedback after fitting new disks
Evening all,
I fitted new front brake disks\pads a couple of weekends ago and now i get weird feedback through the steering wheel.
Everything seems fine on smooth ground and i get no vibration through peddle when braking hard. The problem is i seem to get extra vibration through the steering wheel. Its almost like bumps are not being damped as well as they used to be with the old disks on. It feels a a bit crashy i suppose.
The brake disks i bought were aftermarket cheap disks (wishing i hadnt now) and felt quite heavy. Im wondering if the heavier disks on the front could upset the damping at all??
I thought i may have knocked something loose when hitting the old disks to get them off but i have had a garage take a look and they cant see anything wrong.
Why do people skimp on such important things? It's like any rotating mass, if it's not balanced it will cause vibrations.
probaly a bit of rust (the flakes of rust) stuck behind one of the discs causing it to not sit flat
done this myself a few times... need to make sure the flange is really clean too
Would cause vibration on braking though.
