clio 172 cup
Ok so i took the morning off work to remove the pas pipe the big one from the rack to the pas pump. removed it checked it , its fine. so i look again and its the pipe above that runs from the rack to the reservoir. the alloy pipe close to the rack has been hitting off of the exhaust heat plate due to shite renault engine mounts and split the pipe.!.!
so off to renault to buy the pipe and put a new one on, there is no space what so ever to work. so while i am fitting the new one i will make a slot in the heat plate to allow for the pipe when the engine moves.
So top tip of the day: if your mounts are fubar'd be aware that it might cause further head aches.
Rant Over
Rant Over
