Steering , knocking noise when cold .
MRBILLYUK
  FF Jeden Osiem Dwa
My 182's just 12 months old with 8k on the clock . The past couple of days when i first get in the car there is a knocking / banging noise when i turn the steering wheel to the left or right , it doesn't have to be on full lock either . After the cars warmed up the noise goes .
I don't think its the usual knocking suspension top mount problem but it does sound mechanical . Could it be anything to do with the power steering ?
mine does this on full lock to the right, like a sort of clunking noise...
i think its because its on coilovers though
Darren S
I think from reading these forums m8, 99% of Clios seem to do it! Mine started the same noise around the 10k mark and Reno fixed it - though they wouldn't tell me what they had done? :S
I think it's started to come back now with 26k on the clock as I've noticed the odd clunk sound, usually on full lock to the left...
D.
MRBILLYUK
  FF Jeden Osiem Dwa
I know about the full lock problem . Mines started doing it just turning left or right , not even half a turn of the steering wheel . If i leave the engine running so it warms up for a few mins it goes away . But it's a loud knock / bang like somethings either catching or something might need lubricating .
I was wondering if it's coincidental its only just started happening with the cold weather .
R
rich[182]
Mine does it on a morning when its real cold, reversing out of drive, then its fine until cars been left overnight, very annoying, almost like a lack of lubrication or something, if I leave the car idling for a few mins to defrost windows it sometimes doesnt happen
  1.6 16v clio priv
Did they change the rubber top mounts when they fitter your suspension apparently you get a noise then if its not changed
mine does this... and i know why.
its the springs moving slightly in their holders on the shock. Mine have only done it since fitting the sportline springs. No real problem, just gets a wee bit annoying.
MRBILLYUK
  FF Jeden Osiem Dwa
^^^ Its just the standard cup suspension , i'll keep my eye on it , see if it gets worse , just seems weird why its started happening now being 12 months old . Maybe the cold weathers got something to do with it :S ?
2004 182 32000 miles. mine is exactly the same pulling off the drive, been doing it for 2 weeks, left it with the dealer & they said they 'greased up the joints' it was fine for a few days but it's doing it again.
