Steering Pulling Aggressively
Car  Renault Clio 172 Cup
I have a 182 Cup that drives nice and straight most of the time. Then every now and then it tries to kill me. I.e pulling across the road, most of the time to the right. It’s had pretty much everything but bottom arms. Am right in thinking a bush maybe goosed? Or the subframe? Thanks.
When it pulls is it during acceleration? When coasting?
I had a pull to the right , changed everything suspension related, still the same
4 new tyres. Problem solved
Thanks guys. I’ve checked for loose bolts etc all ok.
Gonna try some different wheels and tyres today
Sent from my iPad using Tapatalk
Where the ball joint goes into the bottom of the hub is all worn. So new hub time.
Common on hubs. Pinch bolt needs to be fully tight otherwise the balljoint can move up and down about 5mm
