Steering response late
Car  Clio 182 cup
we were racing today for the first time on our new coilovers etc. we had them fitted car aligned and setup with correct toe and camber. But since that the car now doesn't turn when you love the wheel. All response has gone.
To turn right the centre line on the steering wheel points to about 1-1:30 till it starts to react properly. And the same to then go left you have to fully unwind and not until the line is pointing towards 11-10:30 does it then start to turn left. Everything in between has no impact on the steering. This is even worse when going at speed not so noticeable when at 20-30 in the pits.
I have the Spaxx RSX kit. As I said we had it set up properly at 2deg toe and 3deg camber. The thing is awful to drive, doesn't respond made it I possible to drive. Very disappointed!! Please help.
Any suggestion is massively welcome.
