Steering squeak driving me insane
MaxB
Car  Clio 182
Ever since I bought my 1.2 it's had this creak/squeak from the steering, especially at low speeds. It's finally gotten to me so I've had a look and it appears to be coming from somewhere on the rack, possibly around where it comes through the bulkhead. I attached a video and any ideas or advice is really appreciated!:)
Ignore the clunking in the video that's just my steering lock.
Thanks, Max.
  • 20191006_231514.mp4
    32.5 MB
I'm thinking I might have to lubricate the grommet where the column goes through the bulkhead. Any ideas on how to do it and what's best to use?
I have the same problem. Took it to my local Renault garage and they’ve diagnosed the problem as within the rack itself.
I’ve replaced everything else on the front and and so i’m pretty convinced they’re right.
If its not the case of greasing where the column spins in the boot, then being epas another rack is not much trouble. You could go quick rack ;) Not a bad idea as the seals and what not would be brand new
Ahhh that's a pain, will likely just have to live with it then until it gets so bad I can justify a new rack. I've read that there's an idler gear within the rack that likes to become noisy so that's probably it🙄.
Is it possible to buy quick racks for epas clios?? If so I may have to have a look at that🤔
I think you have to use the hydraulic rack casing, can be had for 20-30 off ebay or here maybe. Check this site out
Ahhh I see, thank you. Definitely worth some consideration.
