Where do you guys buy them? See one on ebay but it's in china...Pahh! need 58-55.
A Ali V6, Trackhawk, GTS Dec 25, 2008 #1 Where do you guys buy them? See one on ebay but it's in china...Pahh! need 58-55.
A Ali V6, Trackhawk, GTS Dec 25, 2008 #4 Camera's a 58mm and the lens i've got (Old boy's kit) is 55...Ghetto!
V vibrio Dec 25, 2008 #5 eh? the lens mount will be the same, the lens filter ring may be different. step down 77mm ring 72mm filter step up 72mm filter 77mm ring get them from http://www.surreyphotography.co.uk
A Ali V6, Trackhawk, GTS Dec 26, 2008 #6 vibrio said: eh? the lens mount will be the same, the lens filter ring may be different. step down 77mm ring 72mm filter step up 72mm filter 77mm ring get them from http://www.surreyphotography.co.uk Click to expand... no. Canon is 58..??! Fisheye is a 55mm...Hence needing a ring to step down between the two...
V vibrio Dec 27, 2008 #7 58mm is the filter thread, the lens mount (EOS EF) will be the same to fit it to the camera. Does the fisheye screw into the filter thread on the lens?
