ex Clio 172 owner :(
I was driving up a slight incline today and when I was getting near the top the STOP and handbrake light came on.
Went off after about ten seconds. Hasn't yet come back on despite going up a similar incline.
Got home and research on here found out possibly brake fluid. Checked that, all good as there's fluid inside the neck of the bottle.
I've taken off all fours wheels to check the pads properly. All pads are fine. The backsides of the front discs have slight unworn parts towards the centre of the discs and towards the outer edges.
Now, looking at the rest of the engine bay, I can see an are just below the right hand side of the engine cover where there's some dirt. Looking closer it looks oily and I can see about a tablespoon size amount of oil has collected in a recess. I'd take the cover off to have a proper look but a while back I've chewed one of the torx screws to bits!
Is this where the oil pump is?
Is this likely to cause the stop light to come on?
Am I looking at big bucks if it's the oil pump?
The digital oil level says 0 0 _ _ _ _, the dipstick was reading just above the minimum so I've topped it up a bit. now it's on 0 0 0 0 _ _.
Here's some pics.
Any help greatly appreciated.
Cheers.
Here's some pics.
Cheers.
