Strange Central Locking Issues
Car  Clio 01 Dyn
Hi Fellas,
Need some general info. Been using the searh function for hours, and google etc, but cant get any specific information
Clio 2 - 2001 - RF Central Locking (Not IR)
- Central Locking works from inside the car (Using the Button on dash, both doors and boot lock ok)
- Key Fob wont open or close the doors (LED lights up on the key)
- When i put key in drivers door, central locking doesnt work either.
Ok. i have heard about this thing called the "UCH" which is expensive to buy from Renault and apparently cant be purchased from Third Part. How do i know if this is the problem?
I have disconnected battery, changed battery in FOB, still no luck
So.. Is the Remote central controled by a seperate transponder? Or the UCH? Also i have been told that the motor on the drivers door plays a part in this also..
So i have been told so much i dont know who to believe. Any advice is good .. Thanks in advance
It's probably not the issue, but it is worth a try.
Syncing your key.
1.
Get in the car and shut the doors.
2.
Hold down the central locking button for more than 2 seconds.
3.
The immobilizer LED on the dash will flash, it will then stay on.
4.
Now press the lock/unlock button on the new key fob.
5.
The immobilizer LED on the dash will now go out.
6.
Done.
Iv tried that also. When I hold the central lockomg button down on the dash, nothing happens other than the doors lock or unlock
The immobilizer light just stays at a slow flash. Any ideas?
