Got a bit of random issue that's developed.
Every now and then I get a weird hesitation in the throttle response at around 4k rpm in 4th and 5th gear, more so in 5th gear and only does it on light throttle, if I put a bit more throttle on the problem disappears. Best way to describe would be it's like the hesitation you get around 3k when the engine is cold, i.e when the car is running on the cold map. The problem is more apparent when I'm low on fuel so I'm thinking possibly a fueling issue? Can't see it being an injector as surely the problem would be there constantly? so I'm thinking along the lines of possibly a clogged up fuel filter as I'm sure the car is on the original filter when it came out the factory.
I'm a bit stumped by it really, I've cleaned the throttle body and replaced the the throttle cable, although it did seem to ease the problem a little it's not cured it. Anyone have any other suggestions?
Car's a ph-1 172 btw.
