strange problem
Craig
Car  4 wheels
Ive got a strange problem for one my brake pedal feels like it goes to down
To the floor when i brake and also when i brake my clock and mileage go dim but clocks light up.oh and
My serve light traction control and abs light up aswell Anyone
Know whst it could be?
thanks
Bad Earth, Get someone to sit in the car and brake and indicate, I bet it's like an Xmas tree, you need to clean the connectors in the lights and make them tighter.
Will do mate i have notice the left tail light and indicator do go dim
Or off . Where does the earth go to mate?
It's not technically the earth point, when you take the light plug out the one on the left is the earth wire, the socket on it will likely be black or white with dirt and corrosion and come loose, I ended up soldering mine together to stop this, but a general clean and squeeze the bits together should stop it for a while.
