Strange top end rattle/ misfire
Right
bought an engine this morning and fitted it this afternoon
started up first time and sounded fine , ran it for about 5 seconds only
second startup , sounds like there is a bolt in the top end , I thought might be cam followers as engines been stood
third startup, noise is still there but now misfiring! leave to run for a few minutes give it some revs and the misfire and the rattle disappear completely , then reappears and struggle to re-start the engine .
ive given up for now but all I can think is to check the plugs tommorow ?
any other suggestion ?
p.s. I have a video of this engine running perfect before it was removed from previous car so I know it's a good engine.....
Right , I thought I could be something like that, strange as the engine has only been stood for 3 weeks
, I shall fit the auxiliary belt tommorow and fill up the coolant and give it a good long run
Just to update on this,
the engine sounds great from cold, sounds like a diesel between 1k - 1.3k revs when warm then disapears above 1.3 k
sounds a lot like it could be a dephaser pulley to me ?? :banghead::banghead::banghead::banghead::banghead:
