Hello everyone. We have a 2008 Clio with the double panoramic electric sunroof. Unsurprisingly it leaks...Water seems to collect on the inside of the glass, and then drips onto the seats, and this has got quite bad now. Strangely there's no signs of ingress on the headlining, which is dry and stain free.
After it's rained water collects in the corners of the sunroof and doesn't seem to drain away. So I thought the problem could be blocked drain holes. I've had a good look at the front though, and can't see drain holes anywhere, blocked or otherwise. So question 1 is, where are the drain holes? Is there some trim that needs to be removed to access them?
Second question is, how on earth do you access the drain holes for the rear? On the basis that the rear sunroof is fixed, there doesn't seem to be any obvious place to access them.
Thirdly, as the headlining is dry, is there likely to be a different reason for the water collecting on the underside of the glass?
Hopefully someone can help point me in the right direction.
