my clio (2002) has the same problem, my sunroof makes a noise alll the time. its a common problem apprently. my friend had hers replaced cos it was still under warrenty. i just turn my music up louder. lol
If it's the manual opening/tilting glass panel, take out the glass and grease the front hinges with a silicon type grease. Should sort it out. If it's an electric roof these are more troublesome to cure and not a quick fix.
I sorted mine out with some rubber breeze tape you get around your doors and windows frame in your house lol...just stick it around the edge of the glass and it compacts it tighter so no rattles
The above link which no longer seems to work is an excellent fix for it. basically involved just putting a bit of rubber hosing round the bar bit that presses in next to the handle when the sunroof is closed. I did thi son my girlfriends sunroof last year and it is yet to creak again!
