superchip back to original ecu
will the engine become damaged if i remove the superchip and put the old ECU back on? the superchip was mapped with the turbo running at 18psi. Would the original ecu realise there was a turbo on there and adjust the air/fuel ratio accordingly? Im worried that if i put the original ecu back on, then there wont be enough petrol being supplied to the engine at high boost. I have to remove the old superchip because it is not working properly.
One of my mates has warned me about this but i thought id check it out on here first tho...
Si
