Suspension advice needed!
Car  Clio 1.2 8v (2002)
Hi. I have a clio 1.2 8v (2002) which has a 52mm hole spacing. I am looking to lower it (springs and shocks) and a lot of people recommend the apex or g max kits. However everywhere I look it's either 58mm hole spacing or it's not suitable for 1.2 models. If anyone has a 1.2 with a 52mm and has had it lowered or knows where I can find the right kit I would really appreciate it. Cheers!
think spax do a 52mm kit that works. otherwise you can replace the hubs with 58mm ones which will give you greater choice.
who recommended the g max kit :dapprove:
Might as well change the hubs there only £50 or so from a breakers. It makes the choice a whole lot better.
