Suspension geometry settings??
  RenaultSport clio 172 Cup
Wondering if the standard front suspension geometry settings on my 172 cup are still the best to used as it has been lowered. Just finishing off my suspension mods and am going to get a 4 wheel alignment check done but the settings on the alignment machine are for standard factory 172 set up. Not sure about correcting camber or different toe setting to suit. any help appreciated....cheers.
keep it std with a touch more camber if you have adj bolts.
The way the offsets and scrud radii are on a stock setup do not look kindly on toe in for everyday road use, so i dont reccomend deviating from factory settings by much.
Nice one, just the info I needed thanks :D
