Suspension Help
  Renault Clio 1.2 16v
Does anybody have a diagram or picture of the order of what goes on the top of the front suspension first and so forth?
Just got all new bits and wondering what goes where, bearings, rubber mounts, washers etc.
Help would be appreciated :)
  172/1.2/E30
Should be: spring, top seat of the spring, bearing, rubber mount, liitle metal washer/tube thingy, nut.
Right think I got that, thanks. What about on the top? Is it just the top mount or should there be something underneath?
Dose it matter which way the bearings go? And also where would the knocking fix washers go? Sorry for all the questions
Had another look at it all tonight and the bearing only goes in properly one way anyway so thats all sorted :) think I should be fine now!
Anyone know where I can get OE part numbers (specifically for Clio 172 rear shocks!?)
Go to your local renault parts place, should be able to give you a part number and a quote....then just use the part number online
  Clio 172
Unfortunately, they aren't keen on giving out part numbers - they know you're gonna take it and find somewhere cheaper!
