Suspension
Car  Nothing
Hello,
Now there's lots I don't know about Renaults... tbh I know nothing.
I've been a ford and VW man for the last few years but I'm getting a Y reg 1.2 clio for free with nothing but an idle problem.
Now I want to lower it, around 100-120mm, I like low cars. really low.
I'm on lots of forums and I know its really annoying when a noob turns up and asks questions they could search for that have been asked a thousand times before.
My question is, is lowering it easy? I've seen a thread about 50mm-52mm hub changes etc? Cant I just buy some coils that are capable of going that low without changing the hubs? Also if I were to lower it said 120mm, do you think 15's would sit right in the arches?
Thanks for your time. I'm happy with you to reply with links... I have searched but maybe I'm not doing it right because I'm not getting the answers I'm looking for.
120mm is crazy low and will take a s**t load of work not just coilys i should imagine.
If you've got an 8valve which i guess you have you have a 52mm bolt spacing. so would need the vmaxx ones go to ktech
If you've got a 16valve its probably a 58mm bolt spacing so you could get away with using Ta technics/rokkor coilovers (all the same) which are cheaper.
Changing front hub and such isn't too bigger deal i dont think. im doing the same conversion when funds allow me.
