Clio 172; Megane 1.6
hi all,
got a clio rs 172 ph2 (not cup). I think the synchro has a problem as I find it is often crunching into 5th and sometimes needs a lot of force to get it into 1st. 2nd can also be difficult.
I know I am going to need to change the gearbox (previous owner changed it to a newer version which doesn't have the speedo sensor port on it) or re-case the gearbox in the older style casing. If I change the gearbox, will this cure the synchro issue?
I'm also wondering if there's a guide that someone has made on replacing the gearbox? I haven't done it before but am fairly handy
or do you guys recommend going to a garage?
cheers
cheers
