Put simply the TDC sensor or crank angle sensor merely reads teeth on the flywheel so the ECU knows the positon (in deg) of the crank, and thus the position of any piston.
mostly used for ignition and injection timing/sequensing.
if this was broke, you car wouldnt work yet alone idle.
