RCS 182 cup, RCS 172
Firstly im a specialist in suspension in Australia, we set up race cars for tarmac events and track specific applications.
Ive read so many posts about this topic, we have developed a 172 here for tramac/hillclimbs events and encounted the same problem.
The problem is the drive shaft is too long on the drivers side.
When a 172 is lowered certain angles change, in this case the inner cv joint is put under such aggresive angle it is binding up(the knocking you hear) when under load(cornering/turning) as the car is driven around a corner the inertia is transfered to the outside causing the car to roll, now this roll is causing the body of the car to move down while the suspension is moving up, these two effects are putting the drive shaft under very high angles, thus binding(knocking) will occur.
To make matters worse, when a clio is lowered with a atleast 2 degree's of negative camber this will make it bind up even more.
Thru testing we have discovered that both sides, drivers and passangers drive shafts will bind up.
The only quick fix to this, is reduce the amount of negative camber(this will reduce the drive shaft angle)
a permenent fix is to shorten the drive shafts.
