OK the reason behing this is written below but opinions please
Got this idea of sticking a new engine in my car (VAG 1.9 TDi last generation system not PD)
For simplicity dump the UCH and electronis keep the stock ABS etc just make a stand along system for the indicators etc and use stock VAG system.
Since my car will very soon be out of warently and with 90k on the clock being as my cars had such a hard life I'm worried its not long before something fails on it. Injectors and or pump are a likly problem and with the stupid high cost of them I'm already stressed out as soon as one goes the other won't be far behind and £1k bill for the whole setup is a bit much IMO plus there the aditional worries of UCH etc failing and leaving me stranded without a car.
Parents have offered me there old car for free so I have a car for the time being plus got a suitably sized garage to do the work and parents arn't that against the idea (I'm not sure they know what it means to do a transplant)
I've got a fair few bits and pieces sorted in my mind
Stock brakes and ABS (keep stock dash so only need to have the output from the ECU for it and the TDC)
Bin the UCH get a used UCh plugs and have a wired up plug in replacment unit no UCH issues so no need to touch dash loom imobiliser will be shut off on the old system since there no ECU plus the new system VAG ECU would have it switched off and have the alarm activated.
Not sorted the central locking maybe just bin the system and use an alarm to do it.
Use a 6 speed box (I just want one) even if the 5 speeds easier and fits.
Stock shafts with VAG inners.
Suspension shoulnd't be a huge issue get the battery in the boot for weight etc then see maybe just some higher poundage springs save the hastle of coilovers.
So come on people drive some sence into me I'm not even sure whats I want to do.
