Throttle!!!
  Cooksport Fleet
If i remove the fly by wire is replaced for a cable throttle will i loose the cruize control? or loose any of the effects of havin a fly by wire?
  LY 182
i've been trying to find this out for ages but nobody can give me a proper answer..
well,, i can answer your question yes you will lose cruise
i dont think it can be done on standard management
as you have the issue of what to wire a throttle postion sensor to,, and idle control
anybody who knows if its possible thinking maybe paul at rs tuning?
stevo172-RWD
  clio 172 rwd
you cant run a cable throttle on a fly-by-wire ecu (ph2 172)
as the ecu does not know the thottle position (tps)
also it would go to limp mode or cut off with electric fault.
or more likey not start at all because the motorised thottle body is disconnected.
if you use omex you can use cable throttle on a ph2 172.
or mybe its possible to run a ph1 loom and ecu?
hmmmmm
