Timing belt replacement procedure
Status
Not open for further replies.
Car  Clio 182 Cup
Is there anyone out there that has a definitive guide to replacing a timing belt on a 172/182 Clio ? and, to carry it out using the correct procedure. I have searched the forum with no joy but there seems to be no hard and fast guide. Any help would be appreciated i.e the do's & dont's but, i have all the necessary locking tools and facilitys which isn't an issue for me.
I did once find a Renault guide for it which I shall forward on. The big no no I seem to recall is not to put the TDC pin into the wrong hole ("singger" in the crankshaft, since the balancing hole is next to the TDC hole. However, the pin will not go all of the way in with the balancing hole.
Status
