mad in general
Clio 172 phase 2
I am doing the full timing job on my 172. All genuine parts, cam seals, dephaser etc.... tools!!!
When setting the timing the horseshoe needs to be placed into the inlet cam and rotated clockwise a few degrees to get it to slot into the exhaust cam.
Is this normal? I believe it is.
I have followed the procedure outlined in the workshop pdf and using a video on YouTube. I have been reading/watching things on this procedure for the past 7 years of ownership and will not go any further until I know this is done properly.
I have used a feeler gauge in the top left gap between the horseshoe and slot on the inlet cam, to try and take up the slack so to speak.
No matter what I do, once pulleys are torqued up the inlet cam always rotates anti clockwise. Therefore whenever I re-insert the horseshoe it doesn't just slot in. Little bit of a wiggle does it but using pressure.
The tool will not slide back and forth in the slots without me leaning on it.
Can any the usual suspects assist?
