I've seen these pics around the net and always wanted to give it a go so this evening i finally got round to trying it. Baring in mind my photo editing skills are rather pap and my laptop s**ts itself just trying to run Google chrome let alone Photoshop i think they came out quite well.
I'm sure some of you guys can do much better so here's a quick how to....
The hardest part is finding the right image to start with. Ideally it would be a 360 panoramic shot as the left and right hand sides of the images need to match perfectly for best results. (None of mine are panoramic shots, just landscapes that I have cropped)
The image needs to be at least twice as wide as it is high, with a dead straight horizon line (if it's not straight then you can always straighten it up when cropping)
Now you need to stretch the image, pixels wise to make it square. So for example if it's 2000 wide and 1000 high, you need to stretch the height so its 2000wx2000h
Now rotate the image 180 so it's upside down
Go to Filters -> Distort -> Polar Coordinates. (Make sure you select "Rectangular to Polar" in the box), click ok.
Rotate the image to your preferred way up, add some finishing touches with clone tools etc to neaten it up. Job done.
Lets see what you got
