my advice is zoom zoom zoom and post post post!!!
Take pictures of good looking girls.
Post them on here.
/endz.
LOL! Look at all the sharks. Leave us alone in the intellectuals section!!
When I clicked this thread, I was expecting him to be asking about model cars or something. I was going to suggest some tilt shift action![]()
Lighting is one of the most important parts of the shots as well as the poses. Definitely worth reading up on in advance.
Lull her into a false sense of security before going in for the "special" shots which you can then post on here.![]()
FPMSL!make sure you rub her lycra before hand to create a hoof
Lowest ISO lighting will allow for.
Use a reflector to remove shadows
Large Apperture (Greater than F/2.8)
Make sure she is relaxed, so do them somewhere she will be comfortable.
If using flash, make sure you use a diffuser. if its a built in flash buy some thin rizla and stick one of the flash.
Also, a little fashion photography trick seems to be to cut off the top of the head ever so slightly to make the model appear to fill the frame more and appear more intimate.
large apertures will reduce DOF not what you want for glamour shots..
