To those who dis the Ecotek CB26P
  E36 323i coupe
Interesting... the one fitted on my current car is great. Mid range acceleration is much improved and fuel economy... well I do an average of 57mpg. Need I say more.
As for the noise, you could hear a sort of breathing noise when it was first fitted, but now 20,000miles later, there is no noise whatsoever, and hasnt been any since about 500miles after fitting. Maybe cos I had it fitted by an approved dealer/fitter.
Does anyone have any good experiences of one fitted on a Cup?
  Clio 190bhp Hybrid
Should make a noise. If mine doesnt I check it and set it up like when it was fitted.
I find I get nearer 400 miles out of a tank in my valver with it working, about 350 with it off. Does seem to accelerate smoother too. I also got mine fitted properly and didnt bodge it on.
Rich-D
  E90 LCI 330d
Ive had one and tried it, so I am in a position to "dis" the Ecotek.
Most people just sl*g it from what others say, but I have one next to me now and it will not be going on my Cup!
If you needed to get it fitted by an approved dealer its no wonder you think its great.
Its crap, end of.
they are great.......just like the magnets that people put round their fuel pipes....!!!
(i didnt even know there was "approved dealers" !!).....well.......except the bloke down the road that sells block/green in bags !!
  E36 323i coupe
Quote: Originally posted by scotty16v on 17 September 2003
what is it?
Its a little valve that fits onto the brake servo vacuum pipe, and improves your fuel economy and mid range performance.
See www.ecotekplc.co.uk or .com, not sure
  E36 323i coupe
Quote: Originally posted by BenR on 18 September 2003
If you needed to get it fitted by an approved dealer its no wonder you think its great. Its crap, end of.
Well, mate, theres no point in fitting things to a warrantied car, f***ing it up, and having to fork out sh*t loads of money. Of course, for engineering masterminds like yourself it would be a walk in the park. Also what has it being fitted by an approved dealer got to do with it being great? It works. Proof is in the experience.
  E36 323i coupe
Honestly... no. Or, put is this way, I have not noticed any change, and have had to make a few fast stops! I mean if you were racing or had a more mechanical mind than mine, there may be a change, but I can honestly say, that I have noticed no change on the brakes
They are crap, how exactly do u think it improves it
may be on an old crapped out ford with blocked air filter but apart from that its sh*te.
Rich-D
  E90 LCI 330d
Quote: Originally posted by spirez on 18 September 2003
has it reduced your braking performance any? honestly now!
No, never made a difference to the brakes on my 306
  E36 323i coupe
To 16V Neil... Before fitting, fuel consumption figures
were:
1. Around town - 15 to 40mph = 27 to 30mpg
2. Motorway - 60-85mph = 38-48mpg
3. Extra-urban - 30-55mph = 30-36mpg
After fitting:
1. 33-43mpg
2. 50-60mpg
3. 36-46mpg
0-40mph now 6-7seconds.
0-60mph now 10-11 seconds.
Much more go in 4th and 5th gears.
Much improved rolling acceleration.. ie 40-80mph
The only cars that it IS crap in are cars with turbos.
Because it doesnt work when the turbo kicks in.
Properly fitted it should work in all other cars. There
are two ways to fit it:
1. for better fuel economy
2. for improved performance
Mine was fitted at Automotive Solutions in Grimsby.
Its crap, end of.
Lol, even I fitted my own on my 1.4 16v, its that simple, and Im a mechanical disaster area.
It didnt do anything apart from go sccccccchhhhhluuuurrrrrrrrpppppppp alot. Which annoyed me. So I removed it!
  E36 323i coupe
Well, Rhys, you have just proved my point exactly. You obviously didnt have a f**king clue how to fit it properly.
Mine makes no noticeable noise. At all. And the figures above prove its worth. It cost me £65 all fitted, and I have saved £hundreds on fuel.
WTF?!?!?! You just cut the brake servo vacuum hose and install the Ecosh*te as close to the throttle body as possible, secured with a couple of jubillee clips. Thats it. If you have you pay someone to do that, then Id suggest that its you who "dont have a f**king clue". Jeezus.
And if it makes no noise, its not adjusted properly and not doing what its supposed to (which is not a lot apart from schhhhluuuuuuuuuurrrping).
Jon, while Im here, Ive got these great designer clothes you might be interested in. Theyre so light and finee you cant actually see them. Real quality stuff. You can have them for £500 if you want?
Scotty16v - Do a search over the last year on "Ecotek". Theres been loads written about it.
If you fancy a little mod like this, for just £42.50 I can sell you a Hyper-mega fuel hose technopaperclip. Its easy to fit, quieter than the Ecotek and does exactly the same job.
Rhys
  E36 323i coupe
Well, my last words on the subject are:
1. There is no noise.
2. If, as Rhys suggests, there is no noise because it is
not working, then the change in fuel economy and acceleration must be magic.
3. I dont believe in magic.
4. Rhys uses big words - most of them made up - and clearly
has his head so far up his own arse, there is no light or room for others thoughts and ideas... what a tw*t!
5. Scotty, get one. Try it for 500miles or so. If it doesnt work, tell me, and also try the Ecotek PLC web forum.
Sccccchhhhhluuuuuuurrrpppppppppp!
Or a figment of your imagination...
Its not my problem if you dont understand "big words". Then again, you mentioned in another thread that youre a Copper, so it kind of makes sense....
  Clio 190bhp Hybrid
Mine works and makes a noise unless I turn the valve off. Fuel consumption does suffer with it off so it obviously does do something.
I am running with it off since I last filled up to test this out again.
As to any performance gains, car does seem to pull smoother with it on. Without RRing or 1/4 milingwith it on and off I cant comment on any difference without recorded proof but it does "feel" better with it on.
As with any mod, each car is different and changes differ on each car.
  CTR EK9 turbo
hahaha the emporer has spoken
Of course youre going to get better MPG if youre thinking about getting better MPG with something that says it gives you better MPG.
Why isnt it standard equipment for all economy-angled cars? or have ford, renault, peugeot, vw, vauxhall designers thought of this magical thing?
What a waste of £65 !
Can someone explain in simple terms what the theory behind this thing is? Whats the technical reason it is supposed to work and what is the technical reason it doesnt work?
gd shout king stromba! would like to know the low down in the theory of them working and y people say they dont!
v diff of opiion on this one!
sorry Rhys.....i dont understand what your trying to suggest !!!
LMAO;)
well i personally think that ecotek valves do save fuel...not alot....(a tiny amount) but as for all the other claims.......crock of sh*t !!!
& the only way you will know for sure if it is saving you money is to have the car r/r road tested with & without valve.....guess work just isnt accurate !!!!
  E36 323i coupe
Well, Ford have something very similar fitted to all their cars now, and a lot of companies, Renault being one, acknowledge the virtues of the device. Anyway this is like teaching kids... talking to brick walls, and the such.
STICKER TWONK
  Golf GTi DSG
As someone said earlier, explain how fitted some to a brake servo whatever, effects performance or fuel economy?
Because those old threads have been archived i think.
Jon1978 im laughing my head off at your defence of this, didnt you do any research into the Ecotek before fitting it?
-Rob
  E36 323i coupe
Quote: Originally posted by RobFenn on 22 September 2003
Because  those old threads have been archived i think.Jon1978 im laughing my head off at your defence of this, didnt you do any research into the Ecotek before fitting it? -Rob
Laugh away... I read up on Ecotek from several magazine articles online, Ecoteks own website, friends who had them fitted, spoke to mechanics, spoke to Renault. If you want it defending in a more professional manner than someone with a French degree and little mechanical knowledge can, then ring Automotive Solutions in Grimsby and ask them to explain: 01472 321939. You could also call Mal at Speeding, a shop in East Yorkshire (www.speeding.co.uk), and Larkspeed in Hull. K-Tec Racing also approve it for Renault use... I could go on. I can only defend it, in as far as my experience of it goes.
  E36 323i coupe
Quote: Originally posted by Rhys on 21 September 2003
Thought youd already had your last word on this matter!? :p
Oh, sorry, didnt realise no one had the right the change their mind. Do you spend your whole time going out of your way to be unpleasant? What do you do for a living? Solicitor?
Jon1978 - you were the one who called me a tw*t with my head up my arse. I think thats pretty damned unpleasant as all I did was disagree with you.
