Toe
Ph1 Tom
Going to get the tracking set after fitting the cup arms to my ph1.
How much toe works well? Still want decent turn in but keeping good straight line stability. I suppose parallel is the halfway point...
NorthloopCup
5-10 minutes of toe out will give you the desired turn in, but at the expense of straight line stability. But tbh, it's not horrendous anyway with that amount of toe out. It's only really noticeable on bumpy roads.
Factory figures are toe out as well iirc.
GrahamS
  335d, GT4
I had 2 degrees in on my golf, trashed the tyres after a 1000 miles but was stupidly good in the corners!
for track I run up to 1 deg to in and straight ahead for day to day
