172 Flamer
Hello,
the steering on my Mk1 172 sometimes feels heavy & sometimes light. Tyre pressures are fine (about 32 psi up front & 30 on rears).
So, I checked my pas fluid reservior tank this morning before I went to work (cold engine - as recommended in manual) and the fluid level is right up at the neck of the tank by the cap threads! only a few cm's from the top!!!
The min - max indicator is only about 2/3 rds up the side of the tank so my fluid seems to be far too full. Should I drain some off so that it is back to within the min - max markers? Or maybe even empty the whole thing and fill her up with some fresh stuff? Or, is it ok for it to be so high?
Please advise.
Thanks!
Please advise.
Thanks!
