Top Gearbox Mount?
Lovely jubbly Chris, cheers.
Adam, I think I can just feel it coming through the accel pedal, so it feels like drivers side.
I need to take the battery out and check over the w.e, as aparently, its pretty obvious if they are shagged.
Mine wasnt obvious.
The bolt which goes through it shears off within the mount.
Mine looked fine but it wasnt until i took it all apart i realised it was knackered.
But unless it performs perfectly for 18months or more, surely its easier to just bung the standard item on? lol!
Is it an easy easy job Danny? Gearbox jacked up or something, then take mount off, put new one on?
I never supported anything. There is a lower gearbox mount a bit below it which you can see from the wheel arch. That bolts the gearbox to subframe iirc.
